clankity clank on 550 xp
Old Jun 6, 2009 | 08:38 PM
smilenbob1's Avatar
Default clankity clank on 550 xp
i have a 550 xp with about 200 miles on, and on my right back side of the quad is making a clanking sound, its really noticeable when im turning right. im thinking it could be my brakes but my brakes are tight, so im thinking it could by my cv joints. would anybody else have any ideas. its my second issue i have to fix.
im going to tie up my brake caliper and turn right and see if it does it.
Old Jun 6, 2009 | 09:53 PM
eggenz7's Avatar
sounds like a cv... jack up the rear and put it in drive..see if a tire doesnt spin
Old Jun 7, 2009 | 12:24 PM
war1ock's Avatar
Sounds to me like the joint. Is it still under warranty?
Old Jun 7, 2009 | 08:08 PM
Mongrol's Avatar
"Official Site Skeptic"
Both my quads do it & haven't found the cause after hrs of looking.
Old Jun 7, 2009 | 10:41 PM
smilenbob1's Avatar
no it isnt under warranty. thats the bad part. but what i did was switch drive shafts at the rear from left to right. and clanking isnt there anymore. if it is its very slight. becasue i wanted to eliminate the cv joint to see of the sound was still from the right side. its not there anymore.
Old Jun 8, 2009 | 01:26 AM
HeftyLefty's Avatar
It was probably something loose then. And when you switched shafts and reassembled, you tightened it up. I hope you Loctited all nuts and bolts.
Old Jun 8, 2009 | 08:19 PM
BlueManQuad's Avatar
FWIW - my dealer replaced BOTH rear axles for noise issues. I had 500 miles or so at the time. MrsBMQ's 850 doesn't make any noise - yet - after 350 miles. Mine started when the quad got to almost 500 miles.
Old Jun 9, 2009 | 11:22 PM
smilenbob1's Avatar
i had put the lock nuts back on and retorqued everything. since warranty is off i didnt want to replace something that i shouldnt have. i will leave it for now. its 99% better. i had replaced all my oils. and what a pain in the **** to replace the filter. what do you guys do.
Old Jun 20, 2009 | 10:02 PM
smilenbob1's Avatar
ive been driving my 550 xp for a while now, with only 200 miles on it. there is now a high pitch whine and howl, coming from the back at around 30 miles a hour... so i then checked the cv joints and come to realize that both inner and outer cv joints at the rear where so hot i could not touch them, and that the paint was completely gone. i then touched the front cv joints and they were all cool as a cucumber.
so now i have to replace all the cv joints at the back. with no warranty its going to be pretty costly.
Farmerjoe
Aug 22, 2003 03:03 PM
Majorecho
Jul 31, 2003 11:36 PM
Endoman
Feb 11, 2003 02:31 PM
Raptor660RSC
Dec 31, 2002 12:40 AM
