How to adjust the shocks on my son's mini hummer?
Old Jun 18, 2009 | 11:38 AM
spcamno's Avatar
Default How to adjust the shocks on my son's mini hummer?
Hi,
Anybody knows how to adjust the shocks on these mini hummer atv?
It has several different height notches on the shocks where the spring seat sitting on looks like it they are adjustable.
Thank you in advance!
Old Jun 19, 2009 | 06:46 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Turning that notched ring adjusts the shock..Proper tool would be a spanner wrench...most use a large pair of pliers to turn the ring...turning it so it increases the pressure on the spring stiffens the ride and turning it the other way softens the ride.
Old Jun 19, 2009 | 10:25 AM
spcamno's Avatar
Thanks mywifesquad for your post!
So what is the exact procedure?
Do you have to remove the shock from the atv or I can do that while the whole assembly is still attached?
Also, do I have to compress the spring before I turn that ring?
Thanks again!
Old Jun 22, 2009 | 07:19 AM
KTM Patrol
Former Chinese POW!
It can be done while the shock is on the atv...No compressing of spring necessary...just grab a hold of the ring with a pair of Channel Lock type pliers and give it a twist....it might be tough to move at first but once its been moved it should turn either way as it clicks into the next notch..
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
