Torque Numbers for oil filter. honda 450er
Old Jul 6, 2009 | 12:10 PM
Userx100's Avatar
Default Torque Numbers for oil filter. honda 450er
Can some one please give me the Torque specs for the oil filter and oil drain plug. I seem to have misplaced my service manual. Any help would be great! Thanks a million.
Old Jul 10, 2009 | 12:32 AM
Williebee's Avatar
Post Torque numbers for oil filter Honda 450er
I never use a torque wrench for tighting any bolts never needed one , what i do is use a 1/4" ratchet to tighten for small bolts and a 3/8" ratchet for tighting the oil drain plug i just palm the ractchet's , i've never stripped a fastener this way i guess it helped me because i worked yard and garden equipment for over 20 yrs so i have alot of exsperous ; i learned this methiod after seeing equipment with stripped bolt holes on equipment brought to me that someone else didn't know how much strentch they had .
Oh and about the oil filter if it's got the automtive spin on type you just need to hand tighten it the way you do on car or truck , this is also recomended methiod for the manufacturers instructions on the spin on type filters !
As long as you palm the ratchet it's not a problem them tightened with out stripping the fastners , i just don't trust a torque wrench for soft aluminum these engines use ; however if you're not exsperious with this methiod you should wait for someome else do it for you !......wiliebee..........
Old Jul 10, 2009 | 05:32 AM
hoytultratec's Avatar
I never use a torque wrench either. and never stripped one out.
2007 Grizzley 450
Aug 13, 2015 06:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 5, 2015 05:55 PM
Aug 5, 2015 02:10 AM
Aitch
Jul 21, 2015 09:40 PM
