2006 rancher shifting problem
Old Jul 7, 2009 | 06:27 PM
ace44's Avatar
Default 2006 rancher shifting problem
I have a 2006 rancher 350 4x4 with electric shift. When i first start it it shifts fine with no problems at all. After about 30 minutes of riding when i have it in neutral its reads that im going like 5 mph and when i rev it it goes up. I have to shake the whole bike around while hitting the shift button for it to shift out of neutral. What could be the problem?
Old Jul 7, 2009 | 10:25 PM
chadofohio's Avatar
Have you tried adjusting the clutch?
Old Jul 8, 2009 | 02:19 PM
wolverinekid350's Avatar
maybe you should just get a new clutch if adjusting the clutch doesnt work
Old Jul 8, 2009 | 03:13 PM
HondaMechanic's Avatar
It has a hall effect speed sensor ... I would first remove the speed sensor and check the end to make sure it is clean ...
Old Jul 8, 2009 | 09:25 PM
2020pup's Avatar
Default just maybe
I'm not and expert, so follow all the pros advice but,
I have an 06 rancher myself..I was having almost the same trouble..It would hang in gear (or out). I would have to turn it off and then back on..sometimes get off and kick it (lol). the display would flash etc.. I cleaned the ground and hot cable but that didn't help..I started to take it in the shop but before I did I thought I would be nice and spray it off for the mechanic..Took pressure washer to all the underneath and etc. Let it sit for about 2 hours (cause I took a nap..lol) started it up and it works fine..so just maybe try that..It hasn't acted up since then. I know that sounded crazy and hopefully it would work for you. Good luck
Old Jul 10, 2009 | 06:42 AM
fourtraxhonda300's Avatar
Well..if your electric shifter motor is bad, you could always take it off and put a foot shifter on it.. =)
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
