front lights do not work
Old Jul 9, 2009 | 10:06 AM
rob883's Avatar
Default front lights do not work
2006 800 sportsman front lights do not work any ideas fuses to check ?
Old Jul 9, 2009 | 12:05 PM
switzomatic's Avatar
Default Lights
Check to make sure the harness that plugs into the switch is in properly. Hopefully it's an easy fix! Then check fuses and for power to the lights and switch.
Old Jul 12, 2009 | 10:16 PM
toyoman28's Avatar
The "pod" headlight mysteriously quit working on my '08 sportsman 500 HO last winter. Tore everything apart, checked bulb and fuses...nothing. Got the service manual on line here and started tracing wires and found the hot wire to the that headlight runs up the handlebars and was cut clean off like someone had cut it. Turns out that the wire harness is stretched so tight there that when I turned the bars hard left or right, there was tension on the wire and it snapped. I had a fun time trying to splice in a jumper wire with NO slack to work with. So I guess if you checked the bulbs and fuse, start tracing the wires...
Old Jul 13, 2009 | 10:24 AM
04sportsman600's Avatar
Same thing on my 2004.5 600, the wires were cut inside the pod by the steering shaft. Might be the problem.
Old Jul 13, 2009 | 01:23 PM
700 sportsman's Avatar
Rob, PM me your email, and I'll send you the link to the 07 800 manual, it is almost identical, and has all the wiring diagrams you'd need
ripperray
Oct 10, 2023 02:42 AM
jayking232003
Dec 4, 2019 09:38 AM
txkevin
Sep 21, 2015 02:02 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
MrElussive
Oct 26, 2000 02:30 PM
