T-bap???
Old Jul 15, 2009 | 01:33 PM
muddnjunk's Avatar
Unhappy T-bap???
i am having issues with my polaris 2006 sportsman 800,while out riding after about 3 hrs it started back firing and stalling out,we have done the simple things for checks such as spark, bad gas, compression. so i started the fun stuff with checking connectors and i found that when i unplug the positioner sensor into the throttle body the quad ran good......now does that mean the sensor is screwed or because i unhooked it does the quad go into a limp home mode and at least make it drivable,and the real problem is somewhere else. by the way does t-bap staand for throttle body assembly positioner?
PLEASE HELP
Old Jul 15, 2009 | 01:37 PM
gumbyman's Avatar
run diagnostic and check for codes
Old Jul 15, 2009 | 02:32 PM
G.A.S.'s Avatar
T-BAP sensor stands for temperature and barametric Pressure.
Old Jul 15, 2009 | 03:12 PM
SCRAMBLER500XXX's Avatar
most likely the wires are damaged for the t-bap, you may not be able to see the damage, wires usually broke inside of the wire cover.
Old Jul 15, 2009 | 04:02 PM
muddnjunk's Avatar
how come when i unplug the throttle body positioner sensor the quad runs good....also where is the t-bap located
Old Jul 15, 2009 | 07:11 PM
helmethair78's Avatar
It is in the rubber boot between the air box and the throttle body.
Old Jul 15, 2009 | 07:25 PM
Kerbbirds's Avatar
i had an 800 do that, wasn't the wiring or t bap sensor, the throttle position sensor was out of sync, the dealer has the tools to reset it to where it is supposed to be, takes twenty minutes at the most
GFronk
Sep 29, 2020 06:17 AM
COFatboy
May 2, 2020 12:06 AM
Norternguy
Apr 25, 2013 11:09 AM
Dylan Robinson
16
Sep 20, 2011 11:38 PM
G.A.S.
Nov 28, 2009 09:41 AM
