Leaking oil
Old Jul 21, 2009 | 10:18 PM
BioWare's Avatar
Toxic Ryder
Default Leaking oil
I'm leaking oil from the hose that goes from the oil tank to the motor. there is a metal elbow under the frame. I'm wondering if it is rubbing that is causeing my leakage that might of made a little hole. Can I just run a hose there instead of the elbow or is that a bad idea.
Old Jul 23, 2009 | 01:11 PM
BioWare's Avatar
Toxic Ryder
I guess no one has ever had a oil leak. LOL
Old Jul 23, 2009 | 03:04 PM
MRDS650's Avatar
Canadian and Proud of it !!!
I have not have that one before - Sorry Buddy.
Old Jul 24, 2009 | 02:22 PM
BioWare's Avatar
Toxic Ryder
Do you think i need the little metal elbow, I was thinking just running a straight hose.
Old Jul 24, 2009 | 05:25 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Just went and checked to verify what you are trying to explain. Sorry I didn't catch this thread earlier. All four of mine have those one time use hose clamps and I've had no leaks. I would say replace yours with the adjustable tension clamps and keep an eye on it to make sure that was your issue.
Having said that, the elbow is there because it's a high wear area. You could just use one length of hose from the tank to the case but make sure you have plenty of slack in that area so that the hose has no rubbing at all. You've got round frame tube down there but also square edges from the radiator.
Clean/degrease it real good and replace the clamps first if that's your lowest cost option. If you can get a good deal on the proper length hose then I can't see why that wouldn't work out also.
Old Jul 24, 2009 | 07:35 PM
BioWare's Avatar
Toxic Ryder
I repalced the clamps last year, but now it leaking again. I think that it is the elbow. I'm going to the shop on Sunday to take it all off and see what i find. Might have to replace everything to be on the safe side. At 50.00 bucks a oil change it needs to be fixed.
Thanks Aceisback.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
