clutch set up
Old Jul 26, 2009 | 10:54 AM
camaroraca's Avatar
Cool clutch set up
hey this is my first post so here goes i have a 03 700 sportsmen amd i want to run 26 or 27 inch tires but i need to clutch kit is and i was wondering the hot set up going today i didnt know if i needed a kit or if i just got the two springs thanks alot
Old Jul 26, 2009 | 12:59 PM
gumbyman's Avatar
check aarens or epi for online info.... they have kits that will help you.... but its alot of trial and error to get what you need for you riding style...
Old Jul 26, 2009 | 01:45 PM
700 sportsman's Avatar
yep aaen and epi are good, also I would check out rittercycle.com, I haven't personally delt with him, but I know he knows his stuff, so I would give him a call, and tell him what you want, and he should fix you up good
Old Jul 30, 2009 | 10:13 PM
camaroraca's Avatar
thanks for the replys but i was looking to see whawt springs people wee running like color and stuff so i dont have to buy a kit for 250 and just 2 springs for 25 a peice thanks for the help
Old Jul 31, 2009 | 06:56 AM
sammydogs64's Avatar
Default Springs
I have the same question for a new to me Sportsman 700. I used to have Kawasaki's 650/700's and the forums are very helpful in what springs work for those motors, for some reason I am not getting much info from this site on the subject. I am running stock tires and am looking for a slightly higher engagement rpm to pop over logs and better backshift. The mystery continues.
Old Jul 31, 2009 | 07:16 AM
switzomatic's Avatar
Default Clutch
EPI and Dalton are good. Can't remember what I ran in my 05 800 for an EPI but if you contact them and give your machine, mods, what you want to run for tires, and how you ride they will hook you up. They typically have set-ups for stock and big wheel kits. The EPI I had made a huge difference. Nothing more impressive than being able to pull a monster wheelie with an 800lb machine that is loaded with gear!!!
Old Jul 31, 2009 | 11:03 AM
wildmanben's Avatar
I have a Red/Yellow Primary spring and 58g weights on my 700 and it works just fine. Also have a roller secondary too.
Old Jul 31, 2009 | 12:28 PM
midnightxplorer's Avatar
EPI black works good in the rear clutch
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
