Anybody know what belt works with 2000 magnum with ebs and the 06 500 primary clutch
Old Jul 29, 2009 | 07:33 PM
toolman4's Avatar
Default Anybody know what belt works with 2000 magnum with ebs and the 06 500 primary clutch
My new clutch # 1322555 has a 1/2" less diameter shaft in the center than my old one. Does anybody know what belt will work with this clutch? The 3211069 is too long at 40.875 and I don't know how much 1/2" diameter less equates to my belt legth.
Old Jul 30, 2009 | 07:31 PM
Kerbbirds's Avatar
Go on bike bandit and look up an 06-500 with ebs.
Old Jul 30, 2009 | 10:17 PM
Charlie's Avatar
The part # of the clutch you have was 06 and they used a 3211106 belt for the 800.
But if you go to 07 for the 800 they list two different secondarys using two different belts depending on which model of 800(AR, AL, AQ ect). One is a 3211113 and the other is 3211116. The 116 used the new rapid reaction roller clutch. I think the dimensions are the same just different type of belt. Now in 08 for the 800 they just used the 113 belt. Very confusing and what a mess for a dealer as to what belt to stock. Polaris needs a matrix on all the belts they have as to what they are.
Old Jul 30, 2009 | 10:22 PM
toolman4's Avatar
Thanks kerbbirds, the 06 500 belt is longer than my current belt. It looks like I'm going to have to sell it. I talked with some that thought it would work on my 500 but the grooved drive is quite a bit bigger than the smooth one ebs to ebs and I can't find the right belt.
Old Nov 11, 2009 | 06:34 PM
hdkawi's Avatar
i have done the same thing on my 2000 500 mag changed the clutch now the center shaft is smaller and the belt is a little to long rides about a 1/4 inch out of my secondary still works the belt is a 3211069 did you find a better fit ?
Old Nov 12, 2009 | 07:00 AM
Kerbbirds's Avatar
try the 8oo belt, the3211 113 should work, these belts are pricey, just so you know.
Old Nov 12, 2009 | 08:52 AM
TLC's Avatar
TLC
Here is a cheaper replacement belts for the 3211113.
ULTIMAX® BY CARISLE CW1242-0064 $58
Here is a whole list of aftermarket belts.https://www.justatv.com/pages/atv_dr.../beltdrive.htm
Old Nov 12, 2009 | 06:28 PM
hdkawi's Avatar
thanks i will give it a try
green giant
Jul 13, 2017 12:07 PM
WilliamBos
Sep 30, 2015 08:08 AM
wbfjim
Jun 8, 2015 06:20 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
