Belt Slipping
Have 2009 Sportsman 500 EFI fairly new with 250 miles on it. Last night I was in high and tried to go over some big logs. Hit throttle and none of the tires turned and smelled belt. (Don’t think damaged only a few seconds). Popped it into low and it went right over the logs. I know I should have shifted to low first. Question is should the belt be slipping that easily? Does it need to be tightened and can it be?
I have a 09 800 and i was having belt issues.i burn,t one belt and i even had to replace my cover cause the belt was coming slack and rubbin on it. I up graded my secondary spring and now my belt stays tight. I payed 19.95 to where a kit was 2 to 3 hundred.
Jeff Roper
Feb 1, 2022 11:48 AM
