Belt Slipping
Old Aug 3, 2009 | 08:45 AM
mboyda's Avatar
Default Belt Slipping
Have 2009 Sportsman 500 EFI fairly new with 250 miles on it. Last night I was in high and tried to go over some big logs. Hit throttle and none of the tires turned and smelled belt. (Don’t think damaged only a few seconds). Popped it into low and it went right over the logs. I know I should have shifted to low first. Question is should the belt be slipping that easily? Does it need to be tightened and can it be?
Old Aug 3, 2009 | 08:51 AM
rubicon4 20's Avatar
Banned
were you going through water at all, and if so how high
Old Aug 3, 2009 | 08:59 AM
mboyda's Avatar
no water, was just messing around in the yard. machine was probably only running 5 min. I'll pull the plug tonight anyway. Haven't been through water (1ft+ or so) in a few weeks.
Old Aug 3, 2009 | 09:15 AM
Banned
id bring it to the dealer to take a look, you wont have to pay nothing
Old Aug 3, 2009 | 10:05 AM
UTU's Avatar
UTU
Yes, anything below 7-10 mph you should be in low.. When traversing logs?? YES you should always be in low. Might consider a HeelClicker clutch kit,helps on belt grab & take off..... If you burnt belt bad you should be able to see flat spots and maybe feel/hear it. get a service manual pay for itself in a very short time. Working on the clutch is fairly easy......
Old Aug 3, 2009 | 05:29 PM
eggenz7's Avatar
yep sounds like you had it in high at a time that you needed low..
Old Aug 9, 2009 | 07:18 AM
PHILLIP66's Avatar
I have a 09 800 and i was having belt issues.i burn,t one belt and i even had to replace my cover cause the belt was coming slack and rubbin on it. I up graded my secondary spring and now my belt stays tight. I payed 19.95 to where a kit was 2 to 3 hundred.
Old Aug 9, 2009 | 12:47 PM
95wolv's Avatar
Talking
Eggenz7, you tricky S.O.B. !!! I tried the keys in your avatar, veeeerrrry funny !!
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
