update dripping carb 450-s
Old Feb 19, 2001 | 11:05 PM
Roar's Avatar
Awhile back I made a post asking for info on my carb dripping on my 450-s. Several good ideas were make, but none was the problem. While in cold Arizona I took it apart again, and after through examination(actually all I did was to put on my glasses) I discovered the holes the pin fits in that the float attaches to had worn. The resulting egg shape holes will not allow the float to exert enough pressure on the needle valve to fully shut off the gasoline resulting in the drip. A temporary fix was to shim the pin with some fine wire, but a new carb will probably be needed. I got a little extended warrantee left, so will hound Honda to do the repair.
Thought I'd pass the info on and thanks for the help.
Go forth and ride
98 450-s
14100mi
stock
Blackwaters
00 Kodiak
stock
GregM
Mar 6, 2018 06:53 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
