How do I change the tie rod on a 2002 honda foreman 450
Old Aug 9, 2009 | 01:43 PM
ebertsunlimited's Avatar
Default How do I change the tie rod on a 2002 honda foreman 450
I have a 2002 Honda Foreman. and was wondering the easiest way to remove my tie rods on my bike. thank you... bill
Old Aug 9, 2009 | 05:06 PM
95wolv's Avatar
Most quads have a ball joint with a castle nut holding the end of the tie rod into the spindle,after taking the cotter pin out and removing the nut, a tap on the top of the ball joint with a plastic mallet (so you don't mess up the threads) should pop it out, then you can remove the old and install the new in reverse order.
greg74
Sep 10, 2019 03:03 PM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
