How do I change the tie rod on a 2002 honda foreman 450
Most quads have a ball joint with a castle nut holding the end of the tie rod into the spindle,after taking the cotter pin out and removing the nut, a tap on the top of the ball joint with a plastic mallet (so you don't mess up the threads) should pop it out, then you can remove the old and install the new in reverse order.
TLC
07-11-2015 02:28 AM
