battery won`t charge
its a 02 polaris sportsman 500 and it won`t charge my batteries they go dead after about 6 or 7 starts and won`t charge,i have to put the battery on the charger then it will last 6or7 starts any help is appreciated.
This could be any number of things. The first thing that comes to mind is a bad stator, but that's just because I recently had to work on mine. It could also possibly be a rectifier or a few other things like that. Get it started and disconnect the battery. See what your voltage is at. Also see what the voltage is while the battery is running. If I am correct, the voltage should be around 13-14 volts. Someone else may be able to offer batter advice on this.
chances are the recifier is bad or maybe just unhooked or corroded connection. its not uncommon. look up under the front end under the rack and see if you see a black(i think)box w/ a wire harness in it and check that. imo
Steeldon
Sep 9, 2015 09:38 AM
cody500ho
14
Aug 14, 2015 05:03 PM
