battery won`t charge
Old Aug 9, 2009 | 01:52 PM
roofdogbill's Avatar
Default battery won`t charge
its a 02 polaris sportsman 500 and it won`t charge my batteries they go dead after about 6 or 7 starts and won`t charge,i have to put the battery on the charger then it will last 6or7 starts any help is appreciated.
Old Aug 9, 2009 | 05:49 PM
bcdudley's Avatar
This could be any number of things. The first thing that comes to mind is a bad stator, but that's just because I recently had to work on mine. It could also possibly be a rectifier or a few other things like that. Get it started and disconnect the battery. See what your voltage is at. Also see what the voltage is while the battery is running. If I am correct, the voltage should be around 13-14 volts. Someone else may be able to offer batter advice on this.
Old Aug 9, 2009 | 06:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are the recifier is bad or maybe just unhooked or corroded connection. its not uncommon. look up under the front end under the rack and see if you see a black(i think)box w/ a wire harness in it and check that. imo
Old Aug 10, 2009 | 03:33 PM
thanks guys maybe i should brake down and buy a manual.
Old Aug 10, 2009 | 06:01 PM
bcdudley's Avatar
Check your p.m.
Old Aug 13, 2009 | 08:36 PM
BikKat's Avatar
My battery had no water, after adding distilled water it works fine.
So check you water level within your battery.
Steve
Old Aug 13, 2009 | 10:33 PM
carlobee's Avatar
Steve
same happened to me. just added water and went back fine again.
Old Aug 14, 2009 | 03:18 AM
the battery is 4 months old it has water,thanks
Old Aug 14, 2009 | 07:17 AM
Kerbbirds's Avatar
Probably the regulator - rectifier, black box in front of radiator, left side.
Old Aug 14, 2009 | 12:46 PM
thanks i`ll give that a try next weekend at camp,this weekend is figuring out why i have no brakes and no brake lines leaking and there is fluid,on the 96 sportsman 500
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
cody500ho
14
Aug 14, 2015 05:03 PM
