polaris sportsman 90 electric start problems
Old Aug 19, 2009 | 10:19 AM
bweymouth's Avatar
Default polaris sportsman 90 electric start problems
I'm stumped. I have a 2001 polaris sportsman 90 that runs great but won't start when I use the electric start option. I just put on a new stator and CDI. The battery is fully charged and turns the engine very quickly.
Here's the problem.....When I use the electric start there seems to be a very weak spark and the engine won't start. When I use the kick start, the quad starts on the first kick and runs great. What am I missing here? What should I check? Do you think it is a ground problem?
Thanks!
Brad
Old Aug 19, 2009 | 01:15 PM
tv4fish's Avatar
Brad: When you say that if you use the electric starter there "seems" to be weak spark - have you visibly checked the strength of the spark with the plug out and leaned on the cylinder head or ?? I would see if there actually IS any difference in the spark - by pulling the plug, put it in the HT lead, lean it SOLIDLY on the head, then hit the electric starter and see if you get a nice, bright blue spark (you DON'T want to see a weak, yellowish spark) - then kick it over and see what the spark looks like. If it's not the same, start checking any electrical connections.
Old Dec 11, 2009 | 05:38 PM
stilinsm's Avatar
I was wondering if you ever found out what your problem was. I'm having the exact same issue.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
DOAinNY
Jun 11, 2015 10:34 PM
TJM
Jun 11, 2015 01:28 PM
