Sportsman Transmission Disassembly
I wanted to replace the gasket (sealant) and unfortunately removed the LH transmission case side first which pulled the shift drum so i was not able to mark the detent gear and shift lockout disc. Is there a way to put the gears back together without those marks? thanks
03, 2003, 500, 700, case, disassembly, gasket, gaskets, polaris, sealant, sportsman, sportsmantransmissioncom, teardown, trans, transmission
