Sportsman Transmission Disassembly
Old Aug 22, 2009 | 06:31 AM
robicham's Avatar
Unhappy Sportsman Transmission Disassembly
I wanted to replace the gasket (sealant) and unfortunately removed the LH transmission case side first which pulled the shift drum so i was not able to mark the detent gear and shift lockout disc. Is there a way to put the gears back together without those marks? thanks
Old Aug 22, 2009 | 11:51 PM
HeftyLefty's Avatar
Send Old Polaris Tech a PM. He knows.
Old Aug 23, 2009 | 05:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
give what year and size bike it is as well might help the guys give better info.
Old Feb 4, 2010 | 05:33 PM
bauer92184's Avatar
Bump, I am having the same issue, I have a 2003 Sportsman 700. Anyone have any idea?
Old Feb 4, 2010 | 07:58 PM
The detent is fairly easy to see how it works,BUT since you have removed the gears a manual is really recommended since it will show you the proper position for the gears. Normally the gears alignment is supposed to be marked before removing,but since its already done,its hard to explain re alignment. In other words a pictures worth a thousand words! Good luck opt
greg74
Sep 10, 2019 03:03 PM
cornermike
Aug 10, 2016 06:47 AM
Polaris5
Aug 29, 2015 09:11 PM
JohnnySplat
Aug 6, 2015 12:07 PM
bikedad3
Jul 2, 2015 02:15 AM
