2000 sportsman wierd problem
Old Sep 1, 2009 | 07:10 PM
merc man's Avatar
Exclamation 2000 sportsman wierd problem
On my 2000 sportsman 335 is having a problem i can't figure out. when going forward the engine seems to cut out when you give it more than just a little throttle. I tried changing out the gas and the spark plug but it makes no difference. Also when in neutral and reverse when the override is on it seems to run fine.
How would you disable the reverse limiter I think that could be causing this.
Old Sep 2, 2009 | 03:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the transmission switch to see if working correctly. the override is kicking in when in forward by the sounds of it.
Old Sep 12, 2009 | 11:02 AM
merc man's Avatar
I disabled the reverse limiter and it still cuts out going forward. Any ideas?
Old Sep 15, 2009 | 08:29 PM
merc man's Avatar
turns out it was the air filter......I removed the lid and filter and it doesn't cut out anymore and has about twice as much power.
Old Sep 15, 2009 | 10:30 PM
carlobee's Avatar
good to know that would solve it.
green giant
Jul 13, 2017 12:07 PM
wbfjim
Jun 8, 2015 06:20 PM
Fullblast
May 26, 2015 12:38 AM
sportsman500nc
May 7, 2001 05:22 PM
IndyStorm
Apr 18, 2001 10:02 PM
