05 Sportsman 800 only getting 50-55mph...
Old Sep 15, 2009 | 11:40 PM
popoman's Avatar
Default 05 Sportsman 800 only getting 50-55mph...
So i just bought a used 05 800 with 1300 miles and 161 hours for 3 grand. Think i got a pretty good deal... Ive already put 100 miles and 12 hours with no apparent problems other then it needed rear wheel bearings which i replaced myself (20 dollar ford escort bearings )...
On a long stretch of road slightly down hill it would get 55mph.. going up that same stretch would only get 50 mph.. I checked the rpms at speed and was getting a consistant 5950 rpms... Came with ITP 589 27" mud tires so i know top speed will be lower with these tires due to weight and much higher rolling resistance.
Im guessing though even with these tires i should be getting better then 55mph slightly down hill. Im guessing it must be a belt issue, glazed or whatnot... Its getting nearly 6000 rpm so i dont think its a motor issue??
let me know what you guys have experieced... thanks
Old Sep 16, 2009 | 12:09 AM
hunter8657's Avatar
My friend has an 08 with 27s and thats all he get to. If you want more speed down size the tires
Old Sep 16, 2009 | 12:44 AM
reno82's Avatar
Wouldn't the tire diameter throw off the speedometer? I know on my truck my speedometer reads about 10% slow with my larger tires, so 55 is actually a little over 60. With 27" muds you may be higher than 10%. Add the mph the speedo is off, to the extra wieght of the tires, and you may be about right for that setup
Old Sep 16, 2009 | 08:08 AM
popoman's Avatar
forgot to mention that is gps speed
Old Sep 16, 2009 | 03:26 PM
gumbyman's Avatar
check the belt for width
Old Sep 16, 2009 | 06:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you will looose a little speed w/ the 27" tires. my 06' i had would do around 65. check the belt to see if its sitting up in the clutch about 1/8" and to see if its a bad belt as mentioned.
Old Sep 16, 2009 | 08:47 PM
cscotter's Avatar
my 2007 x2800 will hit between 67-70 according to the spedo on a downhill strech of gravel road.
Old Sep 16, 2009 | 08:57 PM
RticKwad's Avatar
Runs Stealth!
I don't know, I think I am going to remove that Dalton clutch spring. I want a safer bike for steep hills and with engaging the clutch for more bottom end torq it shifts the power more back and down making the front end jumpy. If that makes sense?
Either way Rick Ritter may be able to help guide you with clutch cfg. for top speed etc. with running bigger tires.
Cheers,
R'
Old Sep 16, 2009 | 10:02 PM
popoman's Avatar
thanks alot guys... i will mention i dont really *care* about top speed to much, 50 is plenty on an 4x4 atv.... i just wanted to make sure that the machine will do what it is supposed to do. i was thinking belt and i just wanted to get other opinions as ive only had this atv for a little over a week.
i mean it is reving to 6000rpm so it cant be a motor issue as the limiter is what ~6100rpm?
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
