1995 Xplorer 400 4x4
Old Sep 22, 2009 | 08:02 PM
95xplorer's Avatar
Default 1995 Xplorer 400 4x4
I have a 1995 Xplorer 400 4x4 and it wont idle to save its life.
When it revs down it will back fire from hell. The Plug is black in color and where the exhaust comes out it is wet and black. The quad will run out pretty good but wont idle. This is my first quad so i dont know much about them. I am mixing it 40:1 .
Please send me some helpful info.
Thanks Daniel
Old Sep 22, 2009 | 08:56 PM
ftwflh's Avatar
do a compression check
Old Sep 23, 2009 | 08:30 AM
95xplorer's Avatar
i will do that later today when it warms up. It is 48 degrees out right now.
Old Sep 23, 2009 | 11:03 AM
95xplorer's Avatar
okay did a compression test and it was about 96psi
what should i do now??
Old Sep 23, 2009 | 01:41 PM
drlang's Avatar
Rebuild the top end, new piston, rings, and bore. Good luck Doc
Old Sep 23, 2009 | 06:39 PM
95xplorer's Avatar
Default Engine Pics
I tore the engine apart and this is what i found.
Tell me what you think and what may have caused it.
Where can i get discounted parts for it.
Thanks Daniel
Old Sep 23, 2009 | 09:42 PM
ftwflh's Avatar
DOnt do discount parts! Go with Wiesco piston kit , factory gaskets(400s dont work well with Cometic or cheaper gaskets) get the piston from the shop that does the boreing.
Old Sep 24, 2009 | 08:11 AM
95xplorer's Avatar
should i do a overbore? say like a 1 or 2 mm overbore?
since i am already gonna have it all apart.
Thanks Daniel
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
