Recon Idle adjusment screw
Old Oct 5, 2009 | 01:55 PM
budedm's Avatar
Default Recon Idle adjusment screw
Because I'm thinking about getting a Recon, I was talking to a guy at a trail that had an 05. He said beware of the D shaped idle mix screw that takes a $200 wrench to adjust it. He said he had the Honda place remove his and put the old style in which is the same except the head is slotted. Any truth to this guys story?
Old Oct 5, 2009 | 03:23 PM
HondaMechanic's Avatar
I have 2 , they are for adjusting the air screw .. This is 1 of them , this 1 is made by Honda .. I also have a thumb screw type that came with a jet kit .. There are a few companies make them fairly cheap..
Old Oct 6, 2009 | 06:45 AM
budedm's Avatar
Thanks HM. So, if I buy a Recon, am I screwed (no pun intended) if I need to adjust the idle mix?
Old Oct 6, 2009 | 08:22 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Just for clarification, this is NOT the "idle adjustment" screw. The idle is easily adjusted with a screw driver, out on the trail.
An "air/fuel screw" on the other hand should only need to be adjusted when you first rejet (if you make any changes to the intake/exhaust), and maybe with the change of seasons from hot to cold weather (most folks would never bother!), so I can't figure out what the big deal is here???????
Old Oct 6, 2009 | 09:12 AM
budedm's Avatar
Not really a big deal but I am a tinkerer. And what if I need to disassemble the carb to clean it?
Old Oct 6, 2009 | 10:17 AM
Red Rider
Should be easy to get some tubing and flatten it on one side, to make your own wrench.
Old Oct 6, 2009 | 10:42 AM
The Toolman's Avatar
I bought the little d socket from some tool company I found on the web for $2, but it cost me $5 shipping for it....LOL
On my new recon (07) I opened up the fuel/air screw 1/2 turn an it idles better an stays running when its cold now. Same thing I've done on all the the hondas I've had.
Honda has their bikes set to lean from the factory for my like'ns
Old Oct 6, 2009 | 11:31 AM
Red Rider
All the manufacturers are quite open about the fact that they jet lean to meet emissions standards. I guess this is an owner's clue to fix that first thing when they get their new bike home!
Divergent12
Aug 19, 2023 05:26 AM
cdoren
Aug 16, 2015 11:22 PM
Hondamx751
Aug 13, 2015 01:06 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
MNatv89
Jul 7, 2015 11:36 AM
