Warn provantage plow system Installl PICTS
Old Oct 22, 2009 | 11:57 AM
Deputy_Swan's Avatar
Smile Warn provantage plow system Installl PICTS
System installed pretty easily, hardest part was installing the mounting bracket on the ATV, that took about 1.5 hours. I also noticed that way the winch is mounted and the front brush guard that the cable rubs. So temporarily cut a piece of PVC pipe and laid it over the beam on brush guard where it rubs.
Once the snow starts flying I will prob just remove the front brush guard. The trip springs are heavy duty and should work good for pushing snow. For the dirt I tested it on I needed some extra anti-trip action to I added some tarp straps. I worked the blade pretty hard and it held up just fine. If I would tried this with a Polaris blade it would of been bent all to hell.
Old Oct 22, 2009 | 01:46 PM
mtpockets's Avatar
nice pics. you had better hope those rubber tie-straps don't let go from the blade and come-up and wack you in the face! LOL!
I wonder why you can't adjust the tension on the springs? On my old Galcier2 I could. In fact I did after 1/2 the winter season when they started to stretch-out.
How easy/difficult is it to remove/mount the blade for when you want to go trail riding or whatever?
Old Oct 22, 2009 | 02:42 PM
700 sportsman's Avatar
Could you perhaps get some pics of the end of the push tubes that attaches to the mount, and of the mount itself, I have a warn with pin mount, and was wandering if I wouldn't make something up similar to what yours has
Old Oct 23, 2009 | 12:11 PM
dslanec's Avatar
Well I finished my install of the plow this morning. I can lift the bottom of the blade off the ground 26"!!!!......That is even higher than my old glacier 2 system. Now we just need snow so I can test it out.
Deputy swan-----Not sure if your is different or not. But where you have the winch hooked to on mine the cable just slides through(kind of a pulley system) and the hook hooks up to the plow mount more toward the machine.Mine is on a xp though so that could be the difference.
Jeff Roper
Feb 1, 2022 11:48 AM
shimanok2
Jan 29, 2016 07:37 PM
Oct 10, 2015 10:20 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
