Something Slipping/Wet? (09 T-Cat)
Old Oct 29, 2009 | 01:15 PM
YAMMY450's Avatar
Banned
Default Something Slipping/Wet? (09 T-Cat)
I was driving along the main trail in my area
The beavers had it all dammed up
So I decided to dig a couple holes in their walls along the road to drain the water out
A few places were 3/4 of the way up my 28" tires and half way or less over the cvt case...I just putted along and was in the water for about 30 minutes
(I also have done with many times on my old Kodiak 450 (03) and never had any problems and the water was well over the tires on that machine as it was much smaller and lower)
When I went to continue on, the machine was slipping
I automatically figured some water got in the CVT (even though it shouldnt as it wasnt all thatdeep) and it definatey wasnt deep enough to get in the intakes or anything.....
So I got to a dry part of the trail and took out the drain plug and nothing at all came out
I also gave it several revs in neutral and let it set for about 5 minutes and now its working fine again???
What would have casued this?
Old Oct 29, 2009 | 02:20 PM
EPIChad's Avatar
Only two things i know of that would cause that. One being water in the clutches and the internal wet clutch slipping. Once the internal clutch starts slipping it usually always slips.
Maybe you got just enough water on the clutches or belt to cause them to slip temporaly but by the time you got out it had dried out.
buck80mph
Jan 26, 2011 07:35 PM
OGGYDOGGY
Mar 10, 2010 08:47 PM
BlueRubie
Nov 24, 2008 08:51 PM
Sindelir
Apr 12, 2008 10:34 PM
