Help with Rancher Carb......
Old Nov 11, 2009 | 04:27 PM
jboz29's Avatar
Red face Help with Rancher Carb......
ok i haved clean out gas tank and carb with carb cleaner. looks great. I set allsrews all the way down inside the carb, don't know if this right or wrong, and I adjust the pilot screw from outside to try to get it running righ(which hasnt happened since i took carb apart. It is running really lean. If I put my fingers over 3/4 of theair inlet box, runs like a charm. Only thing I have done differently was someone sugetested putting clear house on some line to make sure you see the gas running thru. From the tank to the carb i put the clear on and added a backup fuel filter. Seems like the gas should run fine from it, but could maybe the hose i have on there now is too big and not letting enough fuel to get to carb? TIA
JACK
Old Nov 11, 2009 | 11:01 PM
oxfordnative's Avatar
Make sure you dont have a air leak on the intake boot. Spray some carb cleaner, not in but, around the carb and boot and see if it changes the way it runs. If it does you have a air leak causing it to run lean. It sounds like you dont have the air screw adjusted properly.
Old Nov 12, 2009 | 05:29 AM
jboz29's Avatar
Default Info on air
Yeah I got new bands to put on both sides of carb and boot. And I have NO idea where the air screw is. I would appreciate it if you could tell me.
TIA
Jack
I would like to ride this weekend since i have messing with this for 4 months or so, just an hour or so on the weekend when i go back to my parents farm in Ohio.
Old Nov 12, 2009 | 04:07 PM
jboz29's Avatar
Anyone????
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
