SP500 stalled in mudhole
Old Dec 2, 2009 | 01:50 AM
GTSnoRacer's Avatar
Default SP500 stalled in mudhole
I was a little stuck in a mudhole today (been through deeper with no problems before), the water was still under the seat...but she died on me. Winched out and couldn't see any mud or water in the airbox...I'm thinking an electrical short....I haven't put any dielectric grease on yet.
Doesn't appear to have any water in the oil, checking the resevoir should be good enough right?
Any thoughts guys?
It almost started right up after I got it out of the water, and ran fine after this whole incident...I guess it's not "unstoppable" afterall.
Old Dec 2, 2009 | 02:35 AM
MrMarty51's Avatar
Check the color of the oil on the dipstick and if it a grey color then I would be changing the oil.
It is a good idea to pull the spark plug/s and crank the engine over a few times to see if any water did happen to get into the cylinder.
I would be a good thing to change the differential lubes too.
Old Dec 2, 2009 | 04:42 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if the exhaust was under water and wasn't reved up enough it would dhut off the water if the pressure of the exhaust flow wasn't enough to keep the water pushed out. it has happened to mine before as well w/ no issues or water inthe enigne. imo
Old Dec 2, 2009 | 05:33 AM
700 sportsman's Avatar
I just had this happen last weekend, I was riding down the creek, and there was tree blocking me, so I had to go back the way I came, and for some reason, I just got to a certain point, and just sat there, so I stayed on my bike and kept it revved up while my hooked up the winch, mine didn't stall, but it sure was gurgling lol. Also, I was thankful my gorilla winch didn't crap out on me again
Old Dec 10, 2009 | 08:42 AM
UP Rider's Avatar
Kinda sounds like a problem I am having with my 05 500HO mine continues to run but in stutter mode when in deeper water and i get a hot light.
Old Dec 10, 2009 | 08:59 AM
TLC's Avatar
TLC
Put dielectric grease on every connection you can see and tack the front rack off and nose lid and do those as well.
Check your pull rope for wetness and dirt,when water gets by the handle which it does easily,there is a pulse coil,flywheel and stator and other things in there that should be dry and clean at all times.
I silicon my pull handle into place,not water gets in that way.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
