wont Idle without choke
Old Dec 11, 2009 | 02:06 PM
MUd&ROX's Avatar
Default wont Idle without choke
I have a 04 rancher that has set for a while and getting around to getting it running again. It has to have full choke to start and once it warms up it still needs about 25% to 50% choke to run smooth. even when after riding if it falls below 25% choke it cuts out and dies.....Idle adjustment? of carb rebuit?
Im new to the ATV world and dont know where the Idle adjustment is.
Thanks in advance!
Old Dec 11, 2009 | 03:30 PM
sdm111's Avatar
2 strokes or 4
Pilot jet is clogged. Take it apart and clean everything real good. Take the carb.off flip it upside down take the bowl off take the brass jets out and clean with carb. cleaner and a piece of wire. Pull the pin out that holds the float on and remove the needle valve and spray the hole with cleaner along with everything else, don't forget to spray the passage holes that you can see in the throttle body. P.s. welcome to the forum
Old Dec 11, 2009 | 04:15 PM
DODGE57HEMI's Avatar
Mopar Man!
You might try running some Sea Foam through the tank first to see if that help before terring apart the carb.
Old Dec 11, 2009 | 06:13 PM
MUd&ROX's Avatar
thanks for the quick responses! tried sea foam and that helped but nota cure. will get into the carb tomorrow. this thing has set for a year and the gas was awful. figured it was jets but im more used to the 8v carbs so not used to the scale......again thanks...will get some pics up when i get her runnin good and a little fixed up!
Old Dec 11, 2009 | 06:56 PM
bsummers12's Avatar
Sounds like your slow or low idle jet is dirty. Carb cleaner and a small enough wire to get into the jet ports to clean them.
Old Dec 12, 2009 | 10:32 AM
MUd&ROX's Avatar
dont know which jet was which but the recessed one was clogged cleaned it all out and runs like a top! thanks guys.....time for the next question!
Old Dec 12, 2009 | 11:13 AM
sdm111's Avatar
2 strokes or 4
recessed one is pilot one in the center is main.
Old Dec 12, 2009 | 04:03 PM
MUd&ROX's Avatar
that was it!
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:54 PM
