'03 Polaris sportsman 500 4x4 running issues
Old Dec 15, 2009 | 01:13 PM
tonyvats's Avatar
Default '03 Polaris sportsman 500 4x4 running issues
I have a '03 500 HO with issues. Starts fine, idles perfect, but when moving it wants to sputter and has no power. Will travel at 5 mph if you do not operate the throttle more than a tiny bit. Once you open up the throttle the issues start. Has new plug, gas filter and I have opened up the carb for inspection. does anyone have any ideas? thanks, Tony
Old Dec 15, 2009 | 01:54 PM
79hugger's Avatar
Have you inspected the cam or checked the valve lash/timing,I know the pre HO engines are more prone to wiping the exhaust lobe but it can still happen due to lack of proper oil changes.It's pretty simple to check if you need detailed help feel free to ask.Welcome to ATV Connection!!!!
Old Dec 15, 2009 | 02:10 PM
tonyvats's Avatar
I hope it's not that serious. Low miles with multiple oil changes... It sounds like when you go in reverse without pushing the reverse limiter button.
Old Dec 15, 2009 | 02:29 PM
79hugger's Avatar
Lets hope not but it is common in the 500 models, what you just mentioned about the limiter sounds like it's CDI related or in the firing.Maybe some of the others have some advice on that
whitty
67
Feb 24, 2021 02:52 PM
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
