05 sportsman 700
Old Dec 15, 2009 | 07:12 PM
bailbud's Avatar
Default 05 sportsman 700
just got it , never had one before , rear brake does not seem to work , no pressure with pumping not sure if just poor fluid of rear brake cylinder . front brakes work fine and will engage the rear .
anyone have a service manual download spot ???
thanks
looking forward to riding
Old Dec 15, 2009 | 07:24 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
The footbrake is ONLY an emergency brake. The lever on the bars engages all brakes.
Old Dec 15, 2009 | 07:52 PM
bailbud's Avatar
so it won't lock up the rear??
Old Dec 15, 2009 | 07:54 PM
popoman's Avatar
there is a bleed screw on the rear caliper. follow the brake hose from the foot master cylinder to find the correct bleeder valve and bleed the brake. if you need more details in how to bleed brakes just ask...
Old Dec 15, 2009 | 07:57 PM
bailbud's Avatar
some bleeding details would be good ,know how to bleed a truck is there any diff??
Old Dec 15, 2009 | 07:59 PM
700 sportsman's Avatar
yes, the lever will lock up the rear, and I the rear breaks aren't noted to be anything special, but I'd try bleeding it as popoman suggested, and you should get some feeling back
Also I'll send you a PM with the 07 700 manual, I know it's 2 years newer, hardly anything changed
Old Dec 15, 2009 | 10:24 PM
popoman's Avatar
bleed just like you would a truck yep... pump the foot pedal hold it open bleeder valve cloe bleeder valve when the brake fluid slows to a stop... repeat until no air bubbles.. When i bought my 800 the guy said "its been to the dealer to fix the foot break like 2 times but it never works" has worked for over 3 months since i bleed it..
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
