Starts, idles, then falls flat
Old Jan 3, 2010 | 08:24 PM
kaw550's Avatar
Default Starts, idles, then falls flat
When I bought the quad I was told it needed a top end. I replaced the parts but found it was just lean because there was no air cleaner.
It would start and run but had not power.
When I got the stock air cleaner it seemed to fix it. It wasn't 100% but it was fine for the back yard.
I put it in storage a few months ago. I drained the gas and ran it dry.
I took it out the other day and I am having the same problem.
It will start and idle but it doesnt want to move.
Actually if I start it and go it will go about 20 before dying out. If I let off the throttle and try again it will go about 5 feet.
How can I tell if it is the carb or the CVT? without taking the CVT covers off.
I did that the last time and they seemed fine.
Old Jan 3, 2010 | 08:30 PM
OneTenCC's Avatar
What kind of quad is it? What engine?
Joel
Old Jan 3, 2010 | 08:50 PM
kaw550's Avatar
Sorry about that
Alpha sport Kolt 90CC
it's either a 2000 or a 2001
Old Jan 4, 2010 | 10:15 AM
OneTenCC's Avatar
Given it starts and idles, I'd be inclined to think it a carburetor issue. A plugged jet or the likes. I'd remove, disassemble and clean the carb.
Joel
Old Jan 4, 2010 | 11:22 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
As long as your not using the stock spark plug.. I think the carb is dirty too..
Old Jan 4, 2010 | 05:44 PM
kaw550's Avatar
I will pull the carb and take a look.
By stock spark plug do you mean the original that came with the quad or the stock replacement.
Old Jan 4, 2010 | 06:29 PM
KTM Patrol
Former Chinese POW!
stock = original
Old Jan 4, 2010 | 06:59 PM
kaw550's Avatar
In that case, no the plug was replaced last season.
Old Jan 4, 2010 | 07:56 PM
KTM Patrol
Former Chinese POW!
More than likely wont even see what is plugging the jets.. you will need to remove both the main and pilot jet and make sure you can see light thru them. the pilot jet has a less than 1/64 dia hole in it...doesnt take much to plug it or even restrict flow. spray carb cleaner and or compressed air thru them and the holes in the carb...
Old Jan 4, 2010 | 08:46 PM
kaw550's Avatar
I will give it a shot. Any idea where I can find what size main it should have?
I did spend a few minutes tinkering with it tonight. It is acting like the carb is not getting enough fuel. It would start run for a minute than stall.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Big600twin
Jun 10, 2015 03:01 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
