atc 200x problems
Old Feb 25, 2001 | 11:06 PM
bokker's Avatar
Yea I was wondering if you could help me my cousin has a 85 200x and it runs good at idle until you romp on it,it just spits and spuders and then it dies so could you help me HONDA ROCKS!!!!!!!!!!!!!!!!!!
Old Feb 26, 2001 | 10:40 PM
350ex's Avatar
First off take the gas line off to make sure it is getting plenty of fuel. If so, remove carb and take float bowl off, clean bowl out, remove the jets and take a wire to make sure all the holes are clean. Take compressed air and blow all the holes in the carb to make sure they are clean. That should take care of your problem.
Old Feb 26, 2001 | 10:43 PM
350ex's Avatar
Oh! put it back together so then you will know if that fixes it.
Old Mar 6, 2001 | 01:16 AM
250sx's Avatar
yeah, it will run alot better if you put the carb back together before you reinstall in on the motor.
Seriously, that sounds like exactly what's wrong. I've had to trikes that did the same thing and they just needed a carb freshening.
Old Dec 27, 2004 | 03:55 PM
skinny's Avatar
Default atc 200x problems
I have a 1983 200x which I have put a 1983 honda 185s motor in. I have bored the cylender .80 over withy a weisco high compression piston in it, it has all neww valves, rockers cam chain and a brand new high performance cam which i order from web cam. It has been ported and polished and a cobra aluminum race series exhaust on it. I put the stock 200x carb on this motor becuase it would not run with the stcok 185s carb on but it wants more fuel . The stock jet in the 200x carb is a 110 and it still wants more fuel but when I put a 115 in it it runs great in 1,2,3, 4, but in 5th gear it bogs down like the choke is on
HELP ME PLEASE
Old Dec 27, 2004 | 03:56 PM
skinny's Avatar
HELP ME PLEASE
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
