1998 400 Prarie only running on choke
Old Jan 21, 2010 | 05:10 PM
funonahonda's Avatar
Default 1998 400 Prarie only running on choke
This is a 1998 prarie 400 2 wheel drive and I juse purchased ityesterday, It will only run when the choke is on and when I turn the choke off it dies. The previous owner said it has been sitting a while, when I start it up it sounds like the motar is knocking alittle but when I rev it up to a constint rpm the knocking goes away, but I don't know if it will go away when it warms up? Thanks for any input.
Old Jan 27, 2010 | 11:00 PM
Autowizzard's Avatar
Sounds to me like the carb is clogged up Newer gas causes a lot of problems when it sits, If you are handy drain the fuel remove and clean the carb(all of it some jets are smaller than a paperclip and will cause what you describe) I'd then change the oil and see what happens from there, The knocking could be bad news or noise from bad fuel or fuel contaminated oil
Old Jan 28, 2010 | 09:23 AM
TLC's Avatar
TLC
Change the gas and clean the carb, if you do not know how to change clean the carb take it off and get your dealer to do it,it will not cost much. Here is a link on how to clean a carb. Disassembly and Cleaning of a Mikuni Round slide Carburetor
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
Big600twin
Jun 10, 2015 03:01 PM
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
