93 Sportsmand 4x4 problems
Old Jan 28, 2010 | 05:30 PM
carnalchris's Avatar
Default 93 Sportsmand 4x4 problems
Ok I tested the voltage going into my 4x4 switch and getting voltage but when I engage the switch I lose voltage to switch and light does not come on this is when it is in drive, but when in reverse and engage switch and push overide button the 4x4 light comes on and 4 wheel drive works. Can anyone help me please
Old Jan 28, 2010 | 05:35 PM
ftwflh's Avatar
Try unplugging the blk wire out of the reverse limiter
Old Jan 28, 2010 | 06:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like maybe the trans. switch is messing up?
Old Jan 28, 2010 | 06:26 PM
TLC's Avatar
TLC
Maybe its your AWD switch,the old push button type were very troublesome thats why Polaris went to a sliding AWD switch in 98 or 99 I think.
Old Jan 28, 2010 | 08:13 PM
Thats what I was thinking was the switch
Old Jan 28, 2010 | 09:14 PM
ftwflh's Avatar
The older machines had the switch in the shifter and it can cause this problem too.
I recommend the rev limiter thing first because it soesnt cost anything and is easy to check.
Try wiggling the shifter and see if the AWD light comes on too.
Old Jan 29, 2010 | 07:26 AM
Kerbbirds's Avatar
Yiou can find a terminal on the circuit board thats hot with the key on and hook the red-grey wires to the hubs to it, the awd button will still control the awd but you will by-pass the shifter switch, Ive done this to several of the older ones and they are still working.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
