300 express fouling plugs
Old Feb 5, 2010 | 08:56 PM
big_kid's Avatar
Default 300 express fouling plugs
hi guys, i have a 97 xpress 300 that likes to foul plugs. everything is stock besides the .040 wiseco piston and crank seals last year. it seems to smoke excessivly though. how or what is the correct procedure to adjust the oil pump. this unit runs great in the summer but seems to run worse the colder it gets outside. anyone recommend a block off and mix the gas/oil. any help is appreciated. thanks...
Old Feb 6, 2010 | 05:43 AM
Most people automatically think its the oil pump when plug fouling starts,check the carb needle and seat,replace if needle worn or you can see ridges/worn places in seat area. They can smoke a lot and foul plugs from too much fuel. If compression is good and seals good as you say,then trying to adjust oil pump is not necessary as it is set from the factory at 50-1 ratio. PS over time carbon can also build up in pipe,remove clean out plug,tap on muffler and run awhile or can even have vatted out,may help a little,BUT 2strokes are going to smoke! OPT
Old Feb 6, 2010 | 07:50 AM
big_kid's Avatar
yea, i was just wanting to confirm the oil pump seting as when the engine was out im sure the adjusting nuts got out of wack. thanks...
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
