Please Help!!! 2000 Sportsman Prop Shaft Issue
Old Mar 11, 2010 | 06:05 PM
Mr. Fancy Pants's Avatar
Default Please Help!!! 2000 Sportsman Prop Shaft Issue
I have searched the forums high and low for my issue and I can't find anything....so here is my question.
I have a 2000 Polaris Sportsman 500. While doing some winter maintenance I noticed the rear u-joint on my prop shaft was bad. I got it out and went to order it to only find out online and from the dealer that Polaris stopped making that prop shaft and u-joint. They went with another that the dealer wants $200 for the replacement assy. I hate to spend the cash when all I need is just the u-joint. I have a hard time believing I can't cross reference it with something else.
I took my old one to Napa and the Napa 338 is a tad bigger than the one I have. I ordered one off ebay that claimed that fit mine and it too is a tad too big (same size as a Napa 338). The Napa 812 looks close so I ordered that and will try it.
Has anyone ever ran into this issue on a 99-00 Sportsman and if so, where did you find a u-joint that would fit? Also, if anyone knows a part #, that would be great.
Thanks in advance for anyone who takes the time to try and help me!!!!
Old Mar 11, 2010 | 07:38 PM
4getful2's Avatar
i can't believe the people at napa couldn't find you a joint. they look like a regular everyday pto type u-joint.
cap diameter,snapring distance and greasable
Old Mar 11, 2010 | 07:58 PM
Actually they ordered a Napa 812 (will be in tomorrow) but not 100% sure it will work because the old u-joint was in such bad shape. We measured the cap for a snap ring outside and the width of the u-joint. If it works I'll update later. If not, I also read that a New Holland dealer might be able to cross reference it for a PTO of some sort. Either way I'll try to update this thread so it can help someone else.
I posted in hopes someone went through this already and could point me in a faster direction with a link or something. I can't believe this is such a PITA, makes me want to sell the Sportsman lol.
Old Mar 12, 2010 | 06:24 AM
bump to the top...
Old Mar 12, 2010 | 08:06 AM
TLC's Avatar
TLC
Here is a hole aftermarket parts post for commom Polaris parts. Many people use the Napa 338 by the looks of it.
Make a list of common numbers we need
Old Mar 12, 2010 | 04:44 PM
TLC - thanks for that link!!!
Well, I finally found the right u-joint. Turns out mine needed the Napa 812 as the 338 was a tad too big. The 812 is a perfect match to the one I took out. I'm glad I didn't need to fork out $200 for the new prop shaft assy. I must have the earlier discontinued prop shaft that they dumped mid 2000. Either way I'll be up and running soon...wish some extra $$$ in my pocket. Thanks to all who helped point me in the direction I needed to go.....
Dammar
Nov 14, 2015 07:41 AM
wbfjim
Jun 8, 2015 06:20 PM
Fullblast
May 26, 2015 12:38 AM
sportsman500nc
May 7, 2001 05:22 PM
IndyStorm
Apr 18, 2001 10:02 PM
