CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Slow tire leak....what do I do?
Old Mar 14, 2010 | 11:27 AM
broadfieldpoint's Avatar
Default Slow tire leak....what do I do?
Title says it all
Old Mar 14, 2010 | 11:36 AM
Slyder01's Avatar
slime it
Old Mar 14, 2010 | 01:33 PM
TheATVSuperStore.com's Avatar
Former Sponsor
I 2nd that. Slime and drive.
Old Mar 14, 2010 | 04:06 PM
If there is a hole you can't find put about 15 PSI in and use a mixture of water and dish soap and pour it over the tire as you rotate it. If you can't find a spot that starts blowing bubbles it's hard to say where it is. If you've tried having a tire store de-rim, clean the rim, glue, and re-install the tire and it's still leaking Slime does work great. Deflate the tire until it doesn't let out anymore air hanging up off the ground. Squeeze in a bottle of Slime after taking out the valve inside the tire stem. Put the valve back in the stem and inflate and ride around. Riding around or spinning the tires in midair will distribute the Slime. You may end up having to replace the valve inside the stem afterwards as it can get gummed up by the Slime.
Old May 29, 2010 | 04:47 PM
brendo907's Avatar
if u find a nail or somthing pull it out and out a plug in it, other wise slime
Old May 30, 2010 | 12:48 PM
brendo907's Avatar
i love those plug kits, never go riding with out on kicking around my car. i have a friend that needs tires and ive probably put 50 plugs into this tire, including on the side wall
Old May 31, 2010 | 05:23 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
If you ever plan on changing or removing your tire for any reason I would avoid the Slime. That is some nasty shiat to have to work in, on, and around. Seems like you can never clean it off of the wheel when you go to change tires. Just my experience though.
Soapy water and a little air pressure go a long way in locating said leak and tire plugs work very well. No muss no fuss.
Old May 31, 2010 | 08:57 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
drive fast
Old Aug 6, 2010 | 11:29 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Take it to a tire shop and let them fix it. I 2nd the do not slime thing. Slime is the worst to work on after. I actually charge customer extra when they have that crap in there tires.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
