starters
Old Apr 12, 2010 | 09:35 PM
mi. gator's Avatar
Default starters
02 500ho sportsman, can't keep starters in it, getting expensive. corroading
Old Apr 16, 2010 | 09:27 AM
Steeves's Avatar
There are lots of threads on this web site addressing this issue. When you do replace your next starter or bendix use some good RTV silicone to seal your pull cord. If you ever have to use the pull cord manually the silicone will break free. Put the silicone on the outside of the housing and the put the pull cord over it. When sealed like this you shouldn't get anymore water in your bendix or starter.
Worked for me after 3 starters and one bendix.
Old Apr 16, 2010 | 10:31 AM
mi. gator's Avatar
thanks for the response, i used regular silicone and not rtv and i used heavy grease around the pull cord, i will try the rtv instead, thanks again. what starter would you recomend using, back to the polaris one or an aftermarket one?
Old Apr 16, 2010 | 10:51 AM
Steeves's Avatar
I have used both the polaris starter and a aftermarket. The aftermarket worked fine. What I did last time was had the starter rebuilt. I think most of the rebuilding is just cleaning. It cost me $36.00 and it is on it's second year now. When I replaced the starter I also put a little silicone on the seal of the starter motor before I put it in place. This may of helped my water infultration as well.
Old Apr 16, 2010 | 11:17 AM
mi. gator's Avatar
I'll give it a try, thanks again.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
