tie rod ends
Old Apr 19, 2010 | 03:43 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default tie rod ends
Was doing a service on the magnum and noticed a very small amount of play on the inner tie rod ends. I'm aware that these are a wear item, so my question is how much play if any is acceptable before replacement. When it's on the ground you can feel it slightly in the handle bars if you were looking for it.
Old Apr 19, 2010 | 04:28 PM
4getful2's Avatar
that is one of those things that is up to the owner,as to when to change.
As for me ,if you just noticed them getting loose and you regularly keep an eye on them,you might want to wait ,'cause odds are the rest of them will start getting loose after a month or two. unless you're planning on taking a long trip.
4getful2's Avatar
then you can justify changing all of them
Old Apr 20, 2010 | 03:40 PM
Pous's Avatar
Does anybody know if you can cross the polaris tie rods at your local parts warehouse? Just looking for a cheaper way to replace them rather than about $30 a pair off ebay.
Thanks
Old Apr 20, 2010 | 05:08 PM
When I decide to replace my wifes I'm going to check my local Tractor supply. They can get ends for about all garden tractors and such. I think I should be able to find a pair that will match. It's worth a look anyhow. $10-$12 vs $25 a piece
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
