2000 325 trail boss need help
Old Apr 19, 2010 | 08:45 PM
racin_33's Avatar
Default 2000 325 trail boss need help
When it is cold it will idle fine,once it's warmed up it won't idle or start without giving it gas.I cleaned the air filter,check the fuel filter.Thanks for any help.
Old Apr 19, 2010 | 10:28 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Needs a valve adjustment maybe? I've seen both cold start issues and hot engine issues from valves being out of adjustment. Choke sticking maybe?
Old Apr 20, 2010 | 04:58 AM
racin_33's Avatar
ok I will check them both.Thanks
Old Apr 20, 2010 | 05:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you try to idle up the adjustment a little to see if it helps? just wondering what it is idling at? also make sure the carb air vents are clear and not pinched.
Old Apr 20, 2010 | 08:09 AM
scootergptx's Avatar
Supersock
Hired Gun!
Try the valve adjustment. .006 intake and exhaust. Does sound like a choke issue though. Couldn't start mine cold on a 90º day without the choke on. Mine still needed a minor tweak now and then.
Is the quad new to you or have you had it a while and it started doing this?
Old Apr 20, 2010 | 08:13 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Id clean the carb.. When its cold it runs off the choke circuit which by passes the pilot circuit..Id guess your pilot jet is plugged.
Old Apr 20, 2010 | 09:02 AM
racin_33's Avatar
Ok I will check all of the following.Thanks for the help guys
Old Apr 20, 2010 | 09:05 AM
racin_33's Avatar
Scooter,I just got the quad I never had a polaris before I never seen a carb like this one,just trying to get some ideas of the nature of the beast.
Old Apr 20, 2010 | 09:28 AM
Supersock
Hired Gun!
Well, they are very cold natured. Not a big deal, just don't plan on firing it up and taking off. They need warm up time.
They changed the dash in 2002, so it may be different on yours. On mine, the choke had 3 settings. Full, half and off. There's also and adjustment (should be under the left side panel below the tank) in the cable. Might want to see if that is out of adjustment. Could explain why you think the choke is off, but the carb is going by the cable and not the switch on the panel.
Oh, there's gonna be two cables there with adjustments. Make sure you are messing with the choke and not the accelerator.
Old Apr 20, 2010 | 10:27 AM
racin_33's Avatar
Yeah I'm trying to find some with a manuel,I want to redo the carb,since I'm that far long.Thanks again.
