sputtering/dieing 07 sportsman 500
Old Apr 25, 2010 | 01:28 PM
shorse's Avatar
Default sputtering/dieing 07 sportsman 500
Well for the past year my 07 sportsman 500 EFI deluxe has had a ver small sputter/miss at low speeds/rpms crawling around... as soon as you give it a bit more gas it clears out, anything above 10 or so mph was fine...
In the past two weeks this has gotten so bad that i can't (afraid to) even drive it now. It has barely enough power to go from a stop unless you are over 1/2 throttle and really getting into it... sometimes if you blip the throttle on off on off with it at 1/4 or more throttle it will get going... It idles rough at 1800 rpms, it varies 20-30 or so rpms intermittently. All this has been intermittent though... i drove it for an hour, then turned it off, let it sit for 20 minutes. got back on it , started it, and it died. then started it again and it idled real rough, i gave it gas and made it go, but at under 10 mph it was bucking me and missing real bad.
Things i did to it lately:
new plug
new oil/filter
i have been running 87 octane in it, hoping to help it i put in 89... it didnt help at all
new air filter
none of this helped... and it keeps getting worse...
When i floor it, i am just as fast as a 2010 sportsman 500 (carb) and it runs great at full throttle.. however out of 5 runs, he did win twice... and thats when my problems had got worse.
what do i need to replace?
also, how do you tighten up the brakes on this machine... my friends quad stops A LOT quicker then mine and the handle seems a lot stiffer, mine moves more. The brakes also squeek when driving slow, however they appear fine, rotors feel good also.
Old Apr 27, 2010 | 07:18 AM
Kerbbirds's Avatar
Needs the TPS , throttle position sensor set, may have to take it to dealer, they have a special tool to do tis.
Old Apr 27, 2010 | 07:44 AM
TLC's Avatar
TLC
Carb cleaning is what I would try first. I was thinking you may have the worn cam syndrome but it would not run good at full throttle if that was the case.
Old Apr 27, 2010 | 07:50 AM
Kerbbirds's Avatar
Its efi, no carb.
Old Apr 27, 2010 | 07:54 AM
TLC's Avatar
TLC
Opps, never mind . Its not one ones with the ECM recall is it?
Old May 13, 2010 | 05:26 PM
shorse's Avatar
how do i know if there is a recall on it?
Can i clean the TPS? Where is it located
Old May 13, 2010 | 06:11 PM
Spdecat's Avatar
I think it's another code 41
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
