Panther 110 wont cut off
Old Apr 29, 2010 | 05:08 PM
cedarstump's Avatar
Default Panther 110 wont cut off
Hello,
My childs panther 110 will not cut off by the switch. I can turn both switches off and it still runs. We have to lift the choke to get it to cut off. Has anyone ever had this problem?
Thanks
Old Apr 29, 2010 | 05:14 PM
befarrer's Avatar
Check for a loose or disconnected plug in the wiring. To kill the ignition, the switch grounds a wire, so if the wire is disconnected, it will keep running.
Old Apr 29, 2010 | 10:52 PM
LynnEdwards's Avatar
Electrical Expert
Yes, completely correct for a five pin CDI and if the kill switch wiring is generic standard (very likely).
Is this your CDI?
Is there a wire there on the kill switch pin, and is it a good connection?
Note that when the engine is running (or cranking even) there is high voltage on this pin coming out of the CDI. Don't be casually grabbing wires near the CDI when the engine is turning. It can be several hundred volts!
Old May 1, 2010 | 09:48 PM
cedarstump's Avatar
Thanks for all the replies. I finally found a broke wire and was able to solder it in place. Thanks again for the help, this site is great.
Bratman2
Aug 6, 2022 01:42 AM
bamax100
1) Engine problems..
Oct 28, 2014 09:28 PM
Danec44
8
Nov 27, 2011 08:59 PM
NickMcNamara
Sep 16, 2010 01:10 PM
Reelgator
Dec 28, 2006 11:16 AM
