850 Idle
Old May 1, 2010 | 12:17 AM
WOLF1's Avatar
Default 850 Idle
Just curious, what is the idle speed on a stock 850? I currently have mine maintaining 1300-1400 rpm at warm idle with no engine light coming on, and no codes. It does search a little bit in tha range for proper idle, but so far so good.
This is after 3 hours of "tweeking", I think I will call it good for tonight and go ride tomorrow.
Old May 1, 2010 | 03:44 AM
MudAddict's Avatar
Mine idles at 1190
Old May 1, 2010 | 06:58 AM
bitterfitter's Avatar
Mine goes between 1190 and 1200.
Old May 1, 2010 | 07:17 AM
colt2245p's Avatar
mine when warm is 1170 cold about 1290
Old May 1, 2010 | 04:36 PM
Charlie's Avatar
You should never adjust the idle speed on an efi engine. That is an air screw preset at the factory and should never need to be changed. If it is not idling correctly there is a problem with the fuel injection system.
Old May 1, 2010 | 10:38 PM
WOLF1's Avatar
Yes, I know about adjusting idle speed. However, I need to. Can anybody tell me what the minimum base idle is supposed to be? This is the idle speed with out any input from the IAC. This measurement can be obtained by pinching off both hoses on top of the throttle body at warm idle, or by blocking the one hose between the intake tube and IAC. This would be a really good piece of info for me, I should have gathered this before the latest mod but didn't. I did ride it all day, and it would intermittently set a code for high idle speed. Runs really good other than a little bit high on idle.
Thanks...Ray
Old May 2, 2010 | 07:54 AM
Throttle cable may be adjusted too tight up by the throttle housing on the bars. Some of the first 850's had to be tightened up to take slack out of the cable, which would cause the controller to think the throttle was hung open, and it would stall the quad when the thumb lever was suddenly released. Mine took about two minutes to fix when it was doing that.
Old May 2, 2010 | 04:27 PM
WOLF1's Avatar
The cable is ok, the reason it idles a little high is because it now has 43mm throttle bodies.
I can fit the plates a little tighter and slow it down, just wondering what base idle is supposed to be.
Old May 2, 2010 | 05:02 PM
WOLF1's Avatar
On a side note; the new Pit Bull Growlers worked pretty well. Put them through a decent test down on the river bottoms. Lots of rocks, sand, mud, crawling over downed trees, they are quite impressive so far.
wrencher82
Sep 30, 2015 04:27 AM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
