Flooded 93 350L
Old May 4, 2010 | 08:34 PM
ss313's Avatar
Default Flooded 93 350L
I just recently bought this bike and it has run flawlessly. I let it set in the garage for two weeks and when I went in the garage tonight the whole place smelled like gas. I tried to start the bike and it only backfires and pops. Everytime that I pull the sparkplug out it is wet with gas. Is it possible that the crankcase is partially filled? If so is there any way to get it out?
Old May 4, 2010 | 08:57 PM
Kerbbirds's Avatar
Check the airbox, the needle and seat in the carb may be bad and the gas went into airbox,, pull the plug and spin the engine to dry it out, after you fix the needle and seat, turn the gas off when not in use.
Old May 4, 2010 | 11:16 PM
Charlie's Avatar
There is a drain in the bottom of the cranckcase towards the left side as you are sitting on it.
Old May 5, 2010 | 05:41 AM
ss313's Avatar
Thanks. I'll try that stuff when I get home tonight.
Old May 8, 2010 | 08:50 AM
ss313's Avatar
OK. I got the case dried out and replaced the spark plug. Still won't start. It turns over and it spits and sputters and will backfire. If you put gas in the spark plug hole it will start and cut right back off.
What I have done:
1) cleaned and rebuilt carb (I had the kit and it needed it anyway)
2) checked compression (100psi)
3) Checked spark with spark gap tester and have strong blue spark
4) removed pull start and flywheel is tight
5) removed belt cover and smelled gas
I am assuming that I probably need crank seals from the gas smell in the belt cover but would like other opinions (I am going to get a clutch puller so that I can look at the seal). Also, what is the general opinion of the compression? I would rather put off a rebuild until this winter if possible.
Thanks in advance.
Scott
Customer Service #1
May 15, 2020 08:46 AM
cornermike
Aug 10, 2016 06:47 AM
Jaymc
Sep 11, 2015 07:45 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
1000gade
Jul 16, 2015 10:48 AM
