Idle issues
Old May 6, 2010 | 03:24 PM
shankelect's Avatar
Default Idle issues
i have a 2000 4x4 500 scrambler that will not idle after heavy acceleration.starts fine and runs strong ,idle screw does not appear to make any difference any ideas?
Old May 6, 2010 | 07:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. by any chance is the carb or gas tank got dirt in it where it might have clogged the idle circuit? how does it throttle up from idle to trail speed? does it come out of it or just die unless you hold the throttle?
Old May 6, 2010 | 07:50 PM
shankelect's Avatar
Default Idle issue
Thanks for the help,it is very likely the gas may have junk in it kentucky fuel is very bad
From idle to wide open is great response but if i do not continually tap the throttle while coasting it dies
Where on the carb is the idle circuit and how might i clean it
thanks again
Old May 6, 2010 | 08:41 PM
hallj86's Avatar
Sorry but this is a good thread to break into and ask what is a normal idle for a 550 efi X2 2010 mine is around 1800
Old May 6, 2010 | 11:57 PM
RLSIII's Avatar
you might need to cheak the cable itself. Right where it goes thru the handle bars there is and adjustment. I would open that just a little. There is a saftey cut off in the throttle assembly you might just be tripping that.
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
