05 Arctic Cat 400 4x4 LCD display not working
Old May 26, 2010 | 01:41 PM
kcornman22's Avatar
Exclamation 05 Arctic Cat 400 4x4 LCD display not working
My LCD display for my instrument pannel for some reason is not working at all. I have no idea what the problem might be, I checked around to see if there was a blown fuse maybe, but I had no luck finding a fuse box, or where the fuse might be. I do not have an owners manual at the moment I am going to order one soon, but does anyone have any ideas why the display is not working?
Old May 26, 2010 | 02:18 PM
cupsz71's Avatar
Cool
This works on the '06 + up models.....
Your fuse(s) are under the seat by the battery (I think). IF you find it - pull the 30amp accessory fuse. THEN remove the battery cables. Wait 5 min. Re-connect the battery and put the fuse back in.
You need to "wipe" the ECM memory to re-set the pod display. This method seems to solve most blank pod problems. If not - check your wiring harness up under the pod to ensure it plugged in to the gauge, and while your at it check ALL your wires running up the front of the handlebars/steering post for any wire chafe'n.
Hope this helps....good luck.
Old May 29, 2010 | 04:13 PM
Fossil's Avatar
"If you haven't any charity in your heart, you have the worst kind of heart trouble." ~Bob Hope
Default Service manual
You can download a free 2005 AC service manual which covers your 400 at the following link.
K&T Parts House Lawn Mower Parts and Chain Saw & Trimmer Parts
Old May 30, 2010 | 07:20 PM
Timmerman's Avatar
The fuse box is down by the rear tire it is the right rear i think if you look at the inside of the fender you will see the fuse cover, two twist screws hold the cover on.
Old Jun 3, 2010 | 07:37 AM
kcornman22's Avatar
The quad is in the shop right now getting the 4 wheel drive fixed. When I get it back this week I will check it out. Thanks for all the help guys!
hugemoth
Jul 20, 2020 03:28 AM
Gtsordo
Jul 13, 2015 10:38 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
