'01 Dinli 90cc idles good,dies when throttled up
Old Jun 12, 2010 | 05:28 PM
shanejoe's Avatar
Default '01 Dinli 90cc idles good,dies when throttled up
I bought a 01 Dinli 90cc 2-stroke oil injected for my son. It acted like I had no or little spark so I replaced stator, race coil and race cdi. cleaned carb. It will start easily and stay running(idle) but when you give it gas it dies. Not sure what to do next. Please help
Old Jun 12, 2010 | 08:17 PM
mbarryracing's Avatar
Symptom of being too lean.
Main jet might be clogged or varnished, try disassembling the carb and giving it a thorough cleaning...
Old Jun 12, 2010 | 10:40 PM
kellysautosport's Avatar
i have the exact issue with my 05 baja 90.. my main jet was clogged really bad, i just finished reassembling it after cleaning it out and making sure the ports in it sprayed by covering one end with my finger and spraying carb cleaner through the other end. i hope it works for me.. maybe u can try the same
Old Jun 13, 2010 | 07:46 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I agree, double check the jets.
If it still does it, do a compression test.
Old Jun 13, 2010 | 08:11 AM
shanejoe's Avatar
Thanks to all for the advise. I will give it a good cleaning and see what happens.
LT80- you said to do a compression test. What kind of numbers should I be looking for?
Old Jun 13, 2010 | 06:11 PM
Toby Cheeseman's Avatar
anything over 100 pounds. Hold throttle wide open while kicking it several times in a row. We have all Dinlis at 48 inches wide. They are very nice. If you wanna see let me know Ill post them!!
Old Jun 13, 2010 | 06:13 PM
Remember make sure the key is in the off position when trying this!!
Old Jun 14, 2010 | 12:35 PM
shanejoe's Avatar
Thanks for all the help. I will get to work on it
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
sticky123
Jun 14, 2015 07:36 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
