Xplorer 300 Clutching
Old Jun 15, 2010 | 06:18 AM
jetmecanic's Avatar
Default Xplorer 300 Clutching
I have 26" tires on my 300 Xplorer. Need to respring the clutch for more low end. Anyone with suggestions? Not too concerned about a loss of top end speed.
Thanks in advance!
Old Jun 15, 2010 | 07:21 AM
Kerbbirds's Avatar
The polaris white spring will help, and not be too radical, the green will be a bit more, maybe fwifth has some ideas he's done some clutching
Old Jun 19, 2010 | 04:51 AM
jetmecanic's Avatar
After some research and advice going with Black/White in the primary and Lavender in secondary. Opinions?
Old Jun 19, 2010 | 08:42 AM
ftwflh's Avatar
I would recommend Polaris white primary stock secondary but lighten up on the setting to 1-1.The higher engagement of the blk/white will get you in trouble in the mud and the stiffer secondary spring will defeat your purpose with the bigger tires
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
rockinkgin
Sep 25, 2015 01:52 PM
jbrewster94
Sep 23, 2015 04:16 PM
