2006 Sportsman 500 Problem
Old Jun 19, 2010 | 03:22 PM
devin_01's Avatar
Question 2006 Sportsman 500 Problem
Im having a problem with my quad at work. It will run fine then all of a sudden start dieing then it will back fire and take off again. Also it seems like you cant get full throttle out of it. It surges kinda at full throttle. Im not sure what i should be looking for. I dont know if its something to do with the fuel injection or the computer? I pulled the plug and it looked fine but ill pick one up anyways. I also pulled the fuel line off and there seem to be lots of volume but not sure on the presure as i dont have a gauge. If anyone can point me in the right direction that be great.
Thanks Devin
Old Jun 20, 2010 | 10:13 PM
devin_01's Avatar
could it be the computer?
Old Jun 21, 2010 | 06:59 AM
DELUX500EFI's Avatar
BUY AMERICAN!
Do a search.that has been discussed on here before..Was a wire that goes from the crankshaft position sensor(runs from your recoil to your ECU unit)that had rubbed on the red starter wire where they cross on top of motor under airbox...
Old Jun 21, 2010 | 07:08 AM
Kerbbirds's Avatar
Make sure both vent tubes are hooked to the airbox, tps may need to be set
Old Jun 21, 2010 | 12:55 PM
devin_01's Avatar
Ok ill check that out. How do you set the tps?
Thanks
Old Jun 21, 2010 | 02:06 PM
Kerbbirds's Avatar
special tool to set the tps, it may also be the wiring to the t - bap sensor, the sensor on your intake tube between the airbox and the throttle body, they had problems with the wires breaking on them, they sell a kit to repair it
Ltz250goon
Sport Quads
Dec 3, 2015 07:51 PM
toonces
Jun 30, 2015 11:19 AM
BillinIll
Jun 25, 2015 02:44 AM
BillinIll
Jun 19, 2015 01:39 PM
Joe Paul
May 27, 2015 09:04 AM
