1992 polaris 350 motor getting hot
Old Jul 11, 2010 | 05:45 PM
originalshadetreemechanic's Avatar
Default 1992 polaris 350 motor getting hot
Hi everyone,
I just bought a 1992 Polaris 350 ATV used. The motor is getting hot and turning off. Does this model have a cooling thermostat? Are these ATVs known to have water pump problems? The electric cooling fan is working.
Old Jul 11, 2010 | 08:29 PM
4getful2's Avatar
i take it the temp.light is working and coming on??
these models do not have a thermostat and usually don't have much trouble with the water pumps.
you may want to hose the radiator out , and by that i mean to clean all the radiator fins out and make sure it is full of coolant.
if it truly shuts off or dies when it gets hot, you may have some internal damage(blown head gasket or damaged piston)
Old Jul 12, 2010 | 12:44 PM
Default thanks
Yes, the temp light is coming on and working. Thanks for the suggestions. I'll try it.
Old Jul 13, 2010 | 05:19 PM
Skidlid's Avatar
Also, If it was run low on antifreeze you may have to "burp" it. There is a bleeder valve on the top of the head rear of the spark plug. Loosten it until you get antifreeze. Also, check your overflow tube going down to the overflow tank. If there is a leak in that anywhere you will have problems. Good luck.
Gtsordo
Jul 13, 2015 10:38 PM
rcappie4
Jul 10, 2015 04:54 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
